Trick Flow Elbow Problem... Plz Help!!
Old Jul 15, 2003 | 09:43 PM
drewstealth's Avatar
Well i got my 160 stat and trickflow elbow in today. I just finished installing the stat. I started on the elbow but it doesn't fit right. It is a little to long. If i line up the end to the maf it is about 3/4 inch away to far past the throttle body. What do i have to do. The end of the elbows have lips on them so the rubber part hold on a seals but if i cut it then i won't have the lip anymore. I have a slp cai btw. I heard you have to cut the vortech elbow fit but i was told that the trick flow you won't have to cut. Please help i'm trying to get this finished up. Thanks.
Old Jul 15, 2003 | 10:27 PM
anybody?
Old Jul 15, 2003 | 10:30 PM
96speed's Avatar
Cool
Can you slide the SLP CAI over any?
My Moroso CAI had a plate that connected the plastic piece to the air filter. The plate was bolted to the subframe, but eventually I pulled the screws to make the plate adjustable. This made life much easier.
Ryan
Formula Steve
Sep 19, 2023 08:31 AM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 11, 2015 06:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
