Transmission / Speedometer Problems
Old Apr 29, 2012 | 10:20 AM
Jasonz28camaro's Avatar
When I'm driving on the highway in 4th gear the speedometer jumps around like crazy reading anywhere from 30-50mph and the trans will down shift back and forth from 3rd to 4th.
The trans is a 4L60e that has no known problems. I did a search and could not find anything like this, hope you guys have some answers.
Also, could this be causing a misfire if I was driving it hard in the lower gears. The reason i ask is because i was getting it dyno tuned and the tuner was complaining about the speedo moving around and there was also a bad misfire after 4K.
Thanks!
Old May 4, 2012 | 01:38 AM
rat's nest Z-28's Avatar
Re: Transmission / Speedometer Problems
check the vehicle speed sensor (VSS) maybe it's faulty & trans fluid is getting into it...also the connector/wires...
Old May 4, 2012 | 09:51 AM
I have another tread open on ls1tech and after digging around with a tech II and multimeter we found that the connector was bad.
I'm waiting on a new pigtail to come in the mail Monday and hopefully that works.
Thanks for your input. You were dead on.
mattstrike
Mar 12, 2015 10:12 PM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
edxiel
Jan 24, 2015 07:40 PM
Jul 4, 2005 05:00 PM
