trans vibration
Old Apr 19, 2003 | 09:19 PM
platniumta's Avatar
trans vibration
I have a spec stage 3 that I have had for 1 year. It has worked fine so far except that now I have a bad vibration in my trans. I am not sure if it is the clutch or the trans. You can fill it with the clutch in or the out and mostly at high rpms. I have heard of problems with spec clutches and I am wondering if it might be the problem and if it is so I can talk to spec and see if they will take care it since it is not a cheap setup. Any advice would be appreciated.
Old Apr 19, 2003 | 09:59 PM
RENE95Z's Avatar
May want to check the tranny mount. Could be as simple as that. Then work your way towards deeper issues.
jwade88
Jun 14, 2015 09:38 PM
Apr 16, 2015 09:57 AM
Rde Bandit
Mar 21, 2015 10:17 PM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
