View Poll Results: What needs attention first?
Build up the suspension, the trans and rear can take it
0%
Build the trans, before you blow it and ruin the TC!
33.33%
The rear end is a weaker link then the trans
66.67%
Voters: 3. You may not vote on this poll
Trans, rear end, or suspension? plez help me pick
I just finished putting in a 383 that I built and its running like a top. havent had it tuned yet but according to desktop dyno it should be 499 flywheel tq 427 flywheel HP. Anyway right now it is running through a bone stock suspension system a bone stock 3:23 rear end and a stock trans with a SY3500 (yank) 3500 stall.
I have about 1000 leftover and I'm debating these 3 options.
Sphhon tq arm (I need a DS loop)
BMR LCAs, BMR Trans Mount, And a BMR Panhard Bar, And Mabye a T/A rear cover. about 900$
#2 Get the trans Built. current one has 71k on it and seems to have no problems. But the was a small amount of metal in the pan when I flushed it last week. about 1800$
#3 12 bolt with 3:73s 1500- 2400$
Also I thought about getting a 1- LE driveshaft but I'm not sure I need it.
I plan on doing no more engine mods for awhile, But once all I listed is done the motor will probibly get a 125 shot. but that is 1 or 2 years down the road.
thanks!!
thanks!!
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
