Trans Grinding HELP
Trans grinding
What I thought was my clutch might be my trans. It makes a grinding sound every once and a while which gets worse after the car heats up. I can smell clutch every so often, which led me to believe it is the clutch. Can the clutch make a grinding noise?? Or is my trans shot??? How much for a rebuild??
Thanks Erick
Thanks Erick
ive had the same problem..........do a search and you will see ive posted about it a lot.............no one has ever given a clear answer on what causes it.
i have put 15k on my tranny since it started doing that weird noise...........it does it maybe 1 -2 days out of the month.........very random.
nothing has broken (yet)...........but ill have it checked out when i go to replace my clutch someday.
could possibly be throwout bearing.
willie-d-nice
Feb 13, 2015 06:40 AM
. i know i need a new clutch ( street twin is on its way
) i was jsut worried it might be my trans too
. thanks for the info.
