Tranny vibration
Old Apr 11, 2003 | 10:23 AM
Ponykillr's Avatar
Tranny vibration
I have a 95 Z/28 that has a vibration when the car is reved in nutral or shifting gears at high rpms. I have had the car since 1995 and it has done all sorts of funny things but this one seems to be more like a bad problem. if anyone has any sugestions on what could cause that let me know.
Old Apr 11, 2003 | 11:08 AM
norcalstreet's Avatar
Have you had any work done to it? When you say you rev it in neutral and the problem occurs are you moving or are you at 0 MPH?
Three things it could be if you're stationary and this problem occurs. A misbalanced harmonic balancer. May have been caused if it was recently removed and re-installed incorrectly. If you had a front oil leak it might have been removed to get to the timing cover seal or crank seal.
May also be a misbalanced flywheel or possibly some old and worn out motor mounts.
Also check your plugs and wires to make sure they're working okay. A misfiring engine will shake as well.
Old Apr 12, 2003 | 07:22 AM
HungryT/A's Avatar
....or a busted pilot bushing/bearing!
Old Apr 12, 2003 | 07:32 AM
jonaddis84's Avatar
...dont forget the tranny mount.
Old Apr 12, 2003 | 10:45 AM
Ponykillr's Avatar
It feels like a nasty vibration with noise only when i shift ahigh rpms or if its in neutral and its reved. other than that its fine does not vibrate when driving.
Old Apr 12, 2003 | 10:47 AM
Kind of sounds like a tranny mount. It's worth replacing the mount anyway. You can get an 1LE mount at most dealers.
Old Apr 12, 2003 | 01:13 PM
1994CamaroZ28's Avatar
I agree with changing the tranny mount will take like 45 minutes or so to do, but its a simple jack it up take the bolts out and put the new one in, mine cost me 20 bucks, when i got on my car the tranny would smack underneath the car. lol
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
