tranny trouble when shifting at high rpms
Old Apr 20, 2006 | 09:18 PM
JoeKnowsBaseball's Avatar
ok here's the history of this car. it sat not working for like 2 or 3 years. then my friend bought it not running and it needed replaced head gaskets because water got into the cylendars. he got the work done at the mechanic for $800 (pretty good deal i think...) then he got it home and i had several other problems. it idled at 2,200 rpms, shifted into gears really hard. it wouldn't down shift like the electric auto didn't work or wasn't tuned right so he took it to a chevy dealer and had their shop re-tune it to stock settings and everything worked right (after replacing the TPS) idles right and everything. but now when you're stepping on it, when going from 1st to 2nd gear it goes all the way up to almost 6,000 rpms and then a loud pop and then it shifts into 2nd gear. what's the problem? is it tranny trouble? engine backfire? or is the ECU just not reading everything correct yet and driving on it a few miles will set it all straight?
Old Apr 21, 2006 | 12:29 AM
I burn rice too's Avatar
Re: tranny trouble when shifting at high rpms
Try the drivetrain section. Someone there will most likely know more. Maybe a Mod will be nice and move this post for ya.
BigWil
Mar 29, 2015 12:24 PM
Cam's maro
Mar 24, 2015 08:09 PM
97SSdude
Dec 31, 2014 07:43 PM
Cam's maro
Dec 28, 2014 09:30 AM
mattszm6
Dec 14, 2014 07:09 AM
