Tranny temp guage problem..can ya help me?
Well I've installed my tranny guage in and I have a problem. The lighting works but as soon as I turn the ignition it jumps to max temp. Looked at the fuse panel to double check and I have 1 wire ground underneath the dash, another goes to a +12v source. What am I doing wrong?
I put in the place of the fill hole. The fittings they gave out replace that plug. I think I found my problem but won't know for sure until I head downstairs. I grounded my light wire and another wire together. Hopefully that shoudl fix the problem.
Well I double checked everything. 5 wires. 1 ground to engine, 2 sending wire, 3 light to dimmer, 4 light ground underneath dash, and 5 wire to ignition fuse in fuse panel. Soon as I turn the key it jumps to 250. The light use to work and now it no longer works.
How hard can this be? Am I in denial or is the damn guage broke?
Quite possibly it is broken. If the light worked, and now doesn't check the connections again (maybe they came loose).
If you followed the directions and wired them correctly it should work great. If not, try returning it. I know that's a pain because of where you are, but if nothing else, you'll have a new guage that you know is good.
tdigger9899
Sep 7, 2015 10:56 AM
Aug 7, 2015 01:26 PM
