tranny ????
Old Jun 13, 2004 | 11:22 PM
jadams94ta's Avatar
tranny ????
tranny ????
ok i trans is messed up again and ideas wat could be wrong with it here's what it is doing
i drive out the road and it shifts very nice like it should .then when i stop at i red light and go to drive away from te light it shifts fine into second but when it go's to shift into drive itstart to slip real bad . so i pulled over and turned the car off . then the start off again and it works fine . this happens everytime i stop at a red light
any ideas would be helpful
thanks
jason
Old Jun 13, 2004 | 11:25 PM
Spinner's Avatar
Sounds like a bad 2-3 shift solonoid or clutch pack
Old Jun 13, 2004 | 11:31 PM
jadams94ta's Avatar
how can you find out if it them
thanks jason
Old Jun 13, 2004 | 11:40 PM
RED95LT1Z28's Avatar
If it goes away when you shut off the car and start it back up and it's fine till you stop.....my guess is that it's electronic. I mean if it still did it when you shut it off and back on then it would be mechanical. The only reason i'm sayin this is because my car did it in drive and when i stopped at red lights it started off bad but if i manually shifted it it was fine. When i did turn it off it was fine but after a while it screwed up again. Turned out it was a bad vehicle speed sensor. You can tell if it's the vehicle speed sensor if your speedo goes all whacky when it does it. If it does then i'm willing to say it's that sensor.
Old Jun 13, 2004 | 11:46 PM
jadams94ta's Avatar
ok ill check the tomorrow when i get up. is there any way to check the electronic of the trans
thanks guys
anything else
Old Jun 14, 2004 | 12:45 PM
jadams94ta's Avatar
well i took it out the road and the speedo is fine when this happens and one have any ideas
thanks jason
Old Jun 14, 2004 | 07:32 PM
elament's Avatar
If you take it to a tranny shop they can hook your tranny up to a pressure system and check to see if the clutch packs are shifting when the should, I would stay away from COTTMAN I had TWO bad experences with them, I think AAMCO does it for free.
Old Jun 14, 2004 | 08:21 PM
jadams94ta's Avatar
i took it to the tranny shop today so time will tell
jason
Old Jul 14, 2004 | 03:42 PM
jadams94ta's Avatar
well i toke it to a tranny shop and i really dont think they looked at it . i know they didnt hook it up to anything
if i rev it over 2600 it will shift fine just and at low speeds
jason
Old Jul 14, 2004 | 11:18 PM
Yeah steer clear of cottman's they suck....so what happened with your tranny
Old Jul 15, 2004 | 03:21 PM
jadams94ta's Avatar
nothing yet in save up to get rebuilt if i have to
jason
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
