Traction mods for an M6
Old Mar 2, 2003 | 10:43 PM
94YellowTAGT's Avatar
This year at the track i don't want to see 2.3 60's anymore. I have bmr lca's and relocation brackets. I plan on getting dr's but what else would help. I am only looking for 2.0's don't want the chance of breaking a rear.
Old Mar 2, 2003 | 10:44 PM
WheelmanZ28's Avatar
Subframe Connectors will be a HUGE help.
I would also look into a good Torque Arm as well as a stroger Panhard Rod
Old Mar 2, 2003 | 10:56 PM
t-trimz28's Avatar
i agree. subframes and a torque arm will make a world of difference.
Old Mar 2, 2003 | 10:58 PM
My car is lowered about 1.5-2.0 inches. Will SFC's fit? what kind is a good brand to go with?
Old Mar 2, 2003 | 11:25 PM
Blue89Bird's Avatar
HP + Traction + M6 + Stock Rear = 12 bolt/9 inch
Old Mar 2, 2003 | 11:32 PM
LVZ2881's Avatar
I agree..I have blown 2 stockers...however a 9" is out of reach $$ wise so I am going to built my 10 bolt a little stronger.
as for the original question..if you are going to buy a Torque Arm, invest in the adjustable so you can set pinion angle.
Old Mar 3, 2003 | 11:02 AM
BUBBA's Avatar
Put a 200 lb fat guy in the back seat.
It seems to me that since the Lt1 is front heavy, that if you don't lighten up the front, maybe evening up the F-R ratio would put more down pressure on the rear making for better traction.
Its understood that it would create a bit more drag, but at the same time might provide better 60' times.
Ok, lets hear it from those who disagree.JMHO
Old Mar 3, 2003 | 01:39 PM
LimitedEd1LE's Avatar
Get the BMR tubular weld in SFC's. I have them on my car and love them. They also fit right under your car and don't lose any ground clearance. You will lose ground clearance with the boxed ones, but not the tubular.
Old Mar 3, 2003 | 02:57 PM
Z-Attitude's Avatar
I just ordered these DMS SFC's
http://dynamicmotorsports.com/DMS%20SFCs.htm
they are 1-3/4" diameter and the BMR are 1-5/8" for about the same price. Later>>>>>>>
Old Mar 3, 2003 | 03:01 PM
turbo_Z's Avatar
what will a panhard rod do for drag racing... i thought it just keeps the rear under the car when you turn
Old Mar 3, 2003 | 03:06 PM
Z95m6's Avatar
I would second the bmr tubular SFC's if you get some. They tuck up under the car and cannot be seen at all even if you get down and look. They are really cheap and are of the best quality.
Old Mar 3, 2003 | 04:32 PM
BUBBA's Avatar
How about the BMR box type? I realize that they will give you 3/4 less ground clearance, but is that a problem with and UN lowered car? Also are they difficult to see?
I'd just a soon get the stronger box type if they aren't obtrusive and don't mess my ground clearance up significantly.
thx
Old Mar 3, 2003 | 04:49 PM
ImportsRsloths's Avatar
Same problem here with M6............
MY PLAN IS:
Subframe connectors
Adj. Torque Arm
LCA's with Relocators
and wheelie bars.... lol jk
One other thing ive been reading up on who makes the best suspension products with quality fit and performance and it is ALL BMR hands down from what im seeing!!!!!!!!!!!!
Old Mar 3, 2003 | 05:29 PM
mrz28M6's Avatar
Anybody know where i can get the cheapest BMR tubular SFC's? Thanks for anyones help!
Old Mar 3, 2003 | 05:37 PM
www.ls1speed.com has a great price on them, good selection on many brands that have suspension stuff
