TR5 the same as TR55?
Old Jul 2, 2004 | 04:06 PM
Cmr0z28's Avatar
I called Advance Auto and the guy said he only has 6 TR55's and 5 TR5's in stock. He told me NGK updated the TR55's and changed them to the TR5's, but that they're the same plugs. Are they the same or is he another moron working at an auto store?
Old Jul 2, 2004 | 04:16 PM
BUBBA's Avatar
Are you talking about copper, plats, irdadiums, what?
Old Jul 2, 2004 | 04:44 PM
BUBBA's Avatar
I'd check with a couple others places just to make sure.
My info:
Iridiums Stock # 7164 TR55IX 6.95
Double Plats 7862 PZTR5A-15 $11.71
GP PLATS 3404 TR55GP 2.68
V-POWER 3951 TR55 2.24
When I bought my 97SS in 97, I changed the plugs to NGK TR55VX, which are plats. I don't believe they ref those plugs to the camaro anywhere anymore.
At the time, the coppers, which conduct better, but don't last very long were plain old TR55s.
I'd go with the Iridiums at 6.95 ea, if you don't want to change your plugs often.
Don't know where the TR5 number comes from but they may very well be the new numbering system, but again, I'd double check that. JMHO
Old Jul 2, 2004 | 05:25 PM
Hyperspeed97z28's Avatar
I've been running the regular tr-55 v-power's for over 20k, they seem fine still....
Old Jul 2, 2004 | 10:59 PM
Lonnie Pavtis's Avatar
Tr-55's are wide gap (designed for approx .060 gap)
Tr-5's are smaller gap. (.040)
I would not recommend you bend the center electrode that far.
As hard as they are to change, get the correct ones instead of experimenting.
The TR-6 will work well also in a stock motor with a .040" gap. The smaller gap will be easier on the opti as well.
Old Jul 2, 2004 | 11:08 PM
Cmr0z28's Avatar
So do you think I should use TR6's with a smaller gap to go easier on the opti? Please let me know by tomorrow morning...
Old Jul 3, 2004 | 09:06 AM
Is the TR-6 a good idea in a non nitrous motor ??
Will it be that much easier on the opti ?
Old Jul 3, 2004 | 10:01 AM
LWillmann's Avatar
O'Reilly sells the TR55's plain coppers run you roughly $13.00 for all 8.
Old Jul 3, 2004 | 10:47 AM
DrewHMS97SS's Avatar
reading through some stuff at checker, tr5s are a different heat range than tr55
Old Jul 3, 2004 | 12:37 PM
Cmr0z28's Avatar
Thanks guys, I got the TR55's.
HarleyZ28
Oct 5, 2015 06:23 AM
Slayer
Aug 17, 2015 03:55 PM
wzntme
N2O Tech
Oct 4, 2002 03:18 AM
SEB
West South Central
19
Jul 15, 2002 11:43 AM
BlackLS1Z
Jun 10, 2002 08:50 AM
