TPS volts.
Old Oct 20, 2003 | 07:40 PM
supercharged87's Avatar
TPS volts.
What is the TPS supposed to be @ idle and with the key on engine off?
Old Oct 20, 2003 | 08:07 PM
Hotwire's Avatar
engine on or off should be around .75 volts. wide open should be around 5 volts.
Old Oct 20, 2003 | 08:15 PM
Anything from .3v-.9v with throttle closed is acceptable by the pcm. Closer to .6v is good.
Old Oct 20, 2003 | 08:22 PM
Cool, I'm right at .66 volts at idle. Thanks.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
