TPS voltage (read)
TPS voltage (read)
Swapped in a holley 52mm TB and went ahead from seeing some posts on here made the TPS adjustable. In the stock position it was reading .2/4.50 I adjusted it to where its .55/4.98 . Is that too high or is that ok?
I apologize about that. I just looked in my service manual, and at closed it should read between .3 and .9, and at 100% it should be showing "close to 5 volts" as stated in the manual. You're good.
edman
Jan 22, 2015 02:45 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
