TPS question...
Old May 20, 2003 | 01:52 AM
96 WS6's Avatar
TPS question...
Does the TPS have a range? If I adjust mine so the voltage reads anything under 0.61 volts at closed positions it will not read WOT at 100% throttle, it will only go up to 98 or 99. Is that normal?? It seems like minimum to read WOT is 4.14 volts.
Old May 20, 2003 | 05:54 AM
Typically (but not always) it will add about 4.0V to the closed throttle voltage.... e.g. if you start with .50 the WOT reading will be 4.5V. And, I have seen some scanners that will not read above 99%.
Can you verify that when your foot is on the floor, the blades are horizontal/fully open? If not, is the carpet in the way? Is there any resistance in the cable?
Old May 20, 2003 | 02:44 PM
96 WS6's Avatar
Thanks for the reply fred... actually on my TPS if I adjust the voltage too low and I manually open the TB all the way from under the hood it won't read WOT not from the pedal. I thought the computer would take the reading it sees at idle and then calibrate 0-100 that way...
Old May 20, 2003 | 02:59 PM
I guess there must be some sort of formula in the PCM that "assumes" there will be a 4.0V difference (I'm just guessing at that number, but it seems typical), and prorates the TP% using that assumption. If, for some reason, you only got 3.9V gain when you floored it, it would read less than 100%.
I don't think it makes too much difference. The threshold values for "WOT" (power enrichment mode) are all way below 100%..... I think that anything over 70% TP% (my 94 stock program was 66% at 2,800rpm) will kick it into PE mode. There probably isn't any difference in air flow as long as the blades are actually opening all the way.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
