tps problem
Old Apr 25, 2004 | 03:52 PM
lsteavens2's Avatar
tps problem
I was doing a tb bypass and I broke a "tooth" off of the tps and now my car shifts way to late with the shift kit. Plus it won't downshift under wot on the freeway. Does this sound like the problem because I also did a theomstat change and a APC air filter change today.
Old Apr 25, 2004 | 04:02 PM
GreenDemon's Avatar
Oops, sounds like you need a new one. It happens to the best of us. When I did my tb bypass I didn't notice a leak until it was allover the cylinder head steaming away. Luckily I didn't break anything major. Replacing it should make the problem go away.
Thanks for reminding me, mine is probably worn out too, it's pretty slow to downshift and seems like it responds more at certain times more than others.
There's too many sensors on these cars. They like to break a lot.
Old Apr 25, 2004 | 04:36 PM
http://web.camaross.com/forums/showt...hreadid=254456
jackpawt883
Feb 26, 2015 09:04 PM
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
