Tps
The Throttle Position Sensor is on the Throttle Body. The Throttle cable is on the left side and the sensor is on the passenger side. I'm sure someone here has a pic or graphic. You might want to check Shoebox's webpage. Do a search and you'll find him. He has a lot of good stuff there but I can't tell you for sure he as a pic of the TPS.
But, even if you can't find it, it is black and plastic located right on the Throttle Body.
tdigger9899
Sep 7, 2015 10:56 AM
