TPS % Issue?
Old Oct 7, 2007 | 04:31 PM
z28_theantirice's Avatar
TPS % Issue?
My TPS Voltage reads .67 volts at idel with TPS % 0, slowly matting the pedal the TPS voltage climbs up to 3.73 volts and the TPS reads % 87.4 is it not opening up all the way?
Old Oct 7, 2007 | 04:44 PM
Check that! Just found out what was wrong! I went and moved the linkage by hand and seen that one of the bands that holds the elbow to the TB was in a bad position so the linkage would hit it and stop at 87%, moved the band and now its at 100%! God I have been driving around with 87% throttle for a few months now dou!
Old Oct 7, 2007 | 06:22 PM
rskrause's Avatar
Moderator
Talk about a cheap "mod": 13% gain for $0.00! Actually, you lose very little air flow with the last few degrees of throttle plate opening. But still.....
Rich
Old Oct 7, 2007 | 06:42 PM
Rich
Yea I figured it probably doesn't make all that much of a difference in terms of air flow. Wasn't sure how much it effects the PCM because it was only seeing 87%, haven't driven it yet since the change so I don't know if Ill even feel a difference.
Old Oct 7, 2007 | 06:59 PM
windsma's Avatar
Did u get that memo?
jackpawt883
Feb 26, 2015 09:04 PM
armedtrigger
Feb 24, 2015 08:30 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
citizendan1st
3rd Gen / L98 Engine Tech
Sep 15, 2002 08:56 PM
