TPIS Longtubes users...plug clearance?
Old Feb 24, 2004 | 12:33 PM
zhevy-1's Avatar
How's the plug clearance on these headers?
I'd like to know the clearance on the passenger side, 4 & 6 plugs.
Thx-Goose
Old Feb 24, 2004 | 12:54 PM
KGRESOCK's Avatar
I can change a set of plugs....15 minutes easy.
(Cold of course)
Old Feb 24, 2004 | 01:27 PM
speed76demon's Avatar
I have trouble with the one on the passenger side toward the front. It's either 1 or 2
Old Feb 24, 2004 | 01:53 PM
importeater's Avatar
That would be #1 I have been considering TPIS LT's too, would also like to know that. I hear they go in from the top too, true?
Old Feb 24, 2004 | 02:39 PM
zhevy-1's Avatar
If it's on the passenger side, is either 2 or 4. (Even numbers on the passenger side)
I have the Grottyohann longtubes, and those are a nightmare to replace the plugs, might as well take the headers off to do the passenger side.
Old Feb 24, 2004 | 04:14 PM
Black_Z28's Avatar
I haven't personally changed plugs with TPIS headers, but I have seen quiet a few with them. It looked like a pretty simple job from what I could see. I have TPIS' mids and they're not too bad either.
Old Feb 24, 2004 | 06:14 PM
KGRESOCK's Avatar
Iv'e had them on/off a few times the install
is pretty straightforward.
Starter,valve covers and steering joint need to come
off after that no big deal.
However 2 things to note
1. Make sure TPIS knows what kind of
steering link you have unless you don't mind
using a hammer.
2. I had a hell of a time with bolts. The tubes are so
large it doesn't leave alot of room. I am currently
using a 2"stainless allen bolt with a 1" brass spacer/
sleeve with great success.
I have one of the first 4 pair made so I don't know if
any of these design issues have already been addressed.
Kevin
Old Feb 24, 2004 | 07:26 PM
2cub49's Avatar
I've got some pics of my 2 week old from TPiS Longtubes that I've welded the 97 emissions fittings to and had coated here locally.
I haven't installed them yet but the pics show the unique way these headers use 3" by 3/8' regular bolts.
http://community.webshots.com/user/2cub49
Should work well with my 6 psi powerdyne s/c with Methanol Injection that's coming up after the headers and custom exhaust are done.
Old Feb 24, 2004 | 07:49 PM
KGRESOCK's Avatar
I see they took care of problem #2
Good pics/nice set up
Old Feb 25, 2004 | 07:44 PM
2cub49's Avatar
I'll be putting them in, in the next week or so.
A couple of the bolts are shorter and one has a 5/8 head but the bolt tube system should make access and tightening much better than the usual tiny torture header bolts of all the other longtubes.
I'll post some more pics of the installation and ground clearances when they're in.
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
tdigger9899
Sep 7, 2015 10:56 AM
