torque specs on valve covers bolts
A friend of mine had the measurement, it was in inch-pounds, but I forgot what it was.
You'd be safe by just snuging them down with a wratchet until they're firm, but don't crank them down really hard.
The bolts go down thru a sleeve on the inside of the valve cover. I've always been under the impression this should make contact with the boss on the head where the bolts thread in. When it reaches this point thats the proper pressure on the gasket and it should get significantly harder to tighten at that point as well. thats just a guess though, I dont have a inch/lb torque either.
Speeds8erM-1
Jul 18, 2002 11:36 PM
