Top of engine oiling
Old Sep 1, 2016 | 10:27 PM
Colin's Avatar
Hey guys,
I have a rebuilt long block in my 72 Vega. Has a cc503, roller tipped rockers and headers. Also running a GMPP carb intake and 1406. Otherwise stock. Fired it this past weekend. Didn't oil the rockers. Has run maybe a minute in total. Thinking the cam bearings may be incorrectly installed?
Checked the engine by priming with an oil pump primer and drill and the drill was loading down so the pump is at least attempting to push oil.
Ideas?
Old Sep 2, 2016 | 04:57 AM
ACE1252's Avatar
Re: Top of engine oiling
Do you have an oil pressure gauge/sensor installed? If so, does it show pressure, how much pressure, and where is the oil pressure sensor installed?
Old Sep 2, 2016 | 06:44 AM
It hasn't run long enough to get oil going to the rockers. It takes several minutes or longer on an LT1 for some reason on a new build. Hopefully you pre-lubed all the valvetrain.
Old Sep 2, 2016 | 10:55 AM
wjogert's Avatar
Also, I believe if the lifters were dry when installed, they would have to pump up before they will spit oil up the pushrods to the rockers.
I always soak my lifters standing upright in a pail of oil before install.
Also, I usually pull the ignition and fuel pump fuses and then crank the engine until good oil pressure at the gauge. I would just keep running the pump primer until you see oil at the rockers.
pimpen1024
Jul 8, 2015 09:08 PM
FieroLT1
Jun 26, 2015 08:43 PM
Nellsw88
May 26, 2015 05:55 AM
danielbmx
Aug 27, 2002 11:11 PM
mike24
Aug 7, 2002 10:06 PM
