Took 4 or 5 Cranks After 100 octane fillup
Old Apr 15, 2008 | 07:55 PM
MarcR94v6's Avatar
I'm dropping the car off tomorrow for the 500 mile checkup for the new motor and am getting it dynoed as well so I figured, why not, put a little race gas in there.
I had an estimated 2 gallons of 91 left and filled it up with about 6 gallons of 100 octane, closed the cap, got in car and it wouldn't start. Took about 4 or 5 empty sounding cranks, then I got out of the car and I noticed behind me someone was wating for the pump. So I get back in and try to start it and it starts right up? . On my way home I stopped at the gas station and filled up the rest of the tank with 91....so I should be where I was shooting for in the 94-96 range...I just wanted a little better than 91.
Should I be worried? I'm obviously telling the shop tomorrow but I'd like to hear something now as a piece of mind.
Old Apr 15, 2008 | 10:06 PM
greenmachinedriver's Avatar
sounds like a fuel pump pressure check valve problem. also i would not recomend dyno tuning with a higher octane rating than you plan on running on a daily basis. the higher octane will allow the use of mor timing whick may cause ping if using a different fuel.
Old Apr 15, 2008 | 11:06 PM
MarcR94v6's Avatar
thanks for the reply, but I'm not dyno tuning, just getting some #'s.
Old Apr 15, 2008 | 11:38 PM
Pyrodawg's Avatar
maybe u just didnt let it prime all the way?
Old Apr 17, 2008 | 02:04 AM
MarcR94v6's Avatar
No theories anyone else? Seems awfully strange that it happened right after that fill up and hasn't been a problem since.
If I hadn't let the fuel pump prime, the worst that would happen is it would start/idle and then die immidiately because I tried to start it too quick. This was like trying to start a carburetted car that hadn't been started in years.
SpeedJunkee
Jun 6, 2015 04:27 PM
blac94Z
19
May 13, 2015 04:50 PM
Queens94z28
Dec 20, 2014 09:11 PM
ramair96ws6
Feb 12, 2002 03:00 PM
ramair96ws6
Oct 18, 2001 08:22 AM
