too much timing?
Old Jun 13, 2005 | 12:10 AM
Gripenfelter's Avatar
too much timing?
Would too much timing cause a rattle when you shut off the car?
I thought it was the torque converter becayse the bolts seemed a little loose but its still making the rattle.
Kind of like it wants to keep running. Idle seems a bit off too.
When I had the car programmed last year I had a spun bearing at the time so I don't think it was done accurately.
Old Jun 13, 2005 | 12:11 AM
simple's Avatar
Re: too much timing?
sounds like a deisel?
Old Jun 13, 2005 | 12:12 AM
It runs fine but when I shut it off it rattles.
Old Jun 13, 2005 | 11:22 AM
slopokrodrigez's Avatar
Do you have a way to get under the car to tap several areas with a rubber mallet?
Try pulling the coil wire to crank it for a few seconds and see if it will rattle when you stop cranking it to help locate the problem.
Dave
Old Jun 13, 2005 | 05:54 PM
Lonnie Pavtis's Avatar
When you turn off the ignition, you have only residual fuel in the cylinder (which could fire in the cylinder 1 time possibly). There is no injector pulse or spark possible with the key off (so timing is not a factor), so it is likely something else.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
