Too much oil
Old Aug 6, 2007 | 07:16 PM
a4z28's Avatar
Too much oil
I have a leak that i came to the conclusion that it is from the sensor so latlely i have been adding oil and was wondering what would or could happen if u added one or two extra quarts of oil would it hurt anything i was gonna drain the oil and put 5 quarts in it but before i do that wanted to know what u think.
Old Aug 6, 2007 | 07:23 PM
dangalla's Avatar
if you put more oil in your motor than you are supposed to there is a good chance you will blow it up............very quickly
Old Aug 6, 2007 | 08:14 PM
ricehammer's Avatar
Yeah, too much oil translates into the crank slapping it up into a froth which the oil pump can't pick up. Also make sure that leak isn't coming from the back of the intake where it meets the block. The RTV in between breaks down creates leaks. LT1's are famous for this.
Old Aug 6, 2007 | 09:40 PM
Z-RATED94's Avatar
Adding extra oil is a no-no.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
