Titanium Intake Manifold...
Old Feb 10, 2006 | 12:16 AM
Camaro97USAF's Avatar
Ok... just a question to any people that have experience with making sheetmetal intakes. I have a free source of Titanium sheetmetal, how hard would it be to make a Ti sheetmetal intake? I think that'd be kind of neat, and free So I figured I'd ask. I wouldn't be making any, just providing the measurements and dimensions and stuff.
Old Feb 10, 2006 | 12:27 AM
Kain's Avatar
Re: Titanium Intake Manifold...
If memory serves me right, you can only weld/solder Titanium in an oxygen free environment. You'd have to gasket/rivet it together. That is unless you can get into Boeing and weld at their facilities.
Edit: Yeah, you have to weld Titanium in an controlled atmosphere environment, mainly full of inert gasses. Same goes with welding Zirconium and Molybdenum.
Old Feb 10, 2006 | 12:29 AM
rivets would be easy I'll ask if they can weld it, maybe they can, I've seen some come out of the shop welded before.
Old Feb 10, 2006 | 12:33 AM
bdc95ta's Avatar
My uncle works at boeing how much money ya got?? joking
-b
Old Feb 10, 2006 | 01:07 AM
smoknta's Avatar
Getting an oxygen free environment is not that hard. Just use a welding purge tent. It is a small blow up tent that is see through. You fill it with say 100% argon and purge out all the oxygen. Viola! You can get them pretty cheap to.
Old Feb 10, 2006 | 05:02 AM
LameRandomName's Avatar
You might want to give 3M and DuPont a call.
See if they have adhesive products that you could use.
Old Feb 10, 2006 | 05:31 AM
Guest47904's Avatar
Guest
Why not order one of these
It's made of stainless. Strip the paint off and tell everyone it's Titanium. Most wouldn't know which end of a screwdriver to use anyway.
Old Feb 10, 2006 | 06:10 AM
Loadre's Avatar
I believe he was talking about intake manifolds there chief.
Old Feb 10, 2006 | 09:48 AM
yeah intake manifold...
Old Feb 10, 2006 | 10:09 AM
SAR2K's Avatar
You'd spend a butt load of $$$ to have the fab work done correctly. Bolt together or welded. If you did a 100% bolt together intake you'd play hell getting all the bends/joints correct to where you were not losing HP compared to a welded/radiused bend. JMO.
Nice to have a free Ti supply, LOL.
Steve...
Old Feb 10, 2006 | 06:27 PM
Guest47904's Avatar
Guest
Yeah let me see anyone here make their own intake manifold. Chief!
Old Feb 10, 2006 | 06:44 PM
Demon's Camaro's Avatar
If memory serves me correctly Bret Bauer does make them and he is a somebody on here I'd contact him on this subject, if anyone could do it he could.
NOTE: He stated that he wouldnt be the one making it. Which would imply that someone else would be. He has only asked of the possibility.
Old Feb 10, 2006 | 09:10 PM
Daddy2K3's Avatar
Damn AF guys trying to pass the time. Here's an idea for your sheet metal ***....DO SOME DAMN WORK! I've got 14 stuck screws out here and 40 pulled rivets!!
Old Feb 10, 2006 | 10:21 PM
**** man, I'm a crew chief, I'm making sheetmetal work for me
Old Feb 11, 2006 | 01:39 PM
StickMaster's Avatar
Im pretty sure Nitrogen is cheaper than argon
