timing set /water pump
Old Mar 28, 2007 | 08:11 PM
93v8clone's Avatar
if i run a elec water pump do i need to run a factory style timing set or can i run a gen 1 style timing set
Old Mar 28, 2007 | 09:17 PM
95Z28ConvtM6's Avatar
You can run a standard timging chain and gear. There are some nuances such as roller cam, optical triggers on the later LT1s. I'm running a Cloyes roller in mine, but I don't recall the p/n. You just need to plug up the hole in the timing cover. Call the mfg to get the proper p/n or do a search.
Old Mar 28, 2007 | 11:02 PM
93v8clone's Avatar
wow no one else runnin a gen 1 timing chain all i wanted to know was if it was a bolt in thing or if i had to do a high level of cobboledgy on it
Old Mar 29, 2007 | 12:54 AM
ak95ta's Avatar
It is a straight bolt in deal with no cobboledgy needed. Just make sure you get one that is 87' and later factory roller cam.
Old Mar 29, 2007 | 05:27 PM
93v8clone's Avatar
cool thanks
Old Mar 29, 2007 | 07:00 PM
Dave89IROC's Avatar
all depends, you runnig a non-vented(93-94) or vented(95-97) opti???
it matters
Old Mar 29, 2007 | 07:24 PM
93v8clone's Avatar
vented opti motor out of a 94 caprice all b-bodys got vented optis
Old Mar 29, 2007 | 07:42 PM
Dave89IROC's Avatar
ok, then yes, a standard SBC set will work, a double roller will work, you MIGHT need to slightly clearance the timing cover
you never said the year in your first post
Old Mar 29, 2007 | 10:25 PM
95Blackhawk's Avatar
You don't need to plug the water pump bearing hole. I didn't. If you look at your block, there are 2 openings below the water pump bearing housing. Oil would have to fill to the level of the bearing housing to start coming out of there.
Old Mar 29, 2007 | 10:42 PM
Voridaeus's Avatar
Yes, but dirt and other debris can get in.
Old Mar 30, 2007 | 05:55 PM
93v8clone's Avatar
what holes are u talkin bout in timing cover or blocki hope your not talkin leavin holes in timing cover as that will be a little bit of a prob
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
