Which timing set..
Which timing set..
Im doing a cam install along with springs, lifters ect.
Its been recommended i do a timing chain also, i would like to get as rugged as possible, without spending $300 bucks for the LT4 Extreme duty, and one that will work with the stock timing cover and water pump.
So should i just do the stock replacement? or the Lt4 stock replacement? any suggestions are appreciated.
I think the stock LT4 set is only a little less $$ than the ED set, so that is why most people don't go with it for the money. Keeping the stock water pump, stock, LT4 or LT4 ED are about the only choices.
Im running a taboo setup.
Ive got the whole Lt-4 conversion on a new stock replacement chain and sprocket.. ie. cutdown hotcam dowel pin etc.. etc.
car runs fine, no clicks or feeling of breakage....
I guess im proof that it doesn't matter.
Originally posted by Dan_gearhead
If you decide to go with the lt4 ed kit it should not run you $300 more like $206(gmparstdirect)-$225(dal slabaugh)....just some info.
Call Jason Cromer at 1-877-726-8295 to get a quote on the LT4 set.
I put about 30k on my last stock chain set. When I pulled the motor apart for a cam change, the chain was extremely loose and had started wearing/damaging the leading side of the teeth on the cam gear. Knowing that I was going to be spinning the motor even higher this time around, I didnt feel comforatable going back with the stock chain set. IMO, it's worthwhile to look at better chain sets, while the engines apart, if you happen to have the extra money...
if you want to go with an electric water pump and a true double roller timing set checkout this group purchase going on now (pages 3 and 4) http://web.camaross.com/forums/showt...hreadid=213079
$189 for a tough timing set and some free HP with the electric water pump
Steve
Steve
Steve
Steve
ChrisFrez
Feb 1, 2015 08:26 AM
