Timing Set
Old Nov 26, 2003 | 10:42 PM
JKDZ28's Avatar
Timing Set
anyone have the part number for the stock chain etc.
im going with everything new, along with the oversized cloyes gear to take out slack for my cam swap
if anyone has the part number i'd be very greatful
Old Nov 27, 2003 | 12:17 AM
Buttercup's Avatar
Is this a rebuilt engine? Oversized timing gears are for align bored crank journals that move the crankshaft centerline upwards. If this is simply for a cam swap all you really need is a new chain.
new timing chain is p/n 10128485
Old Nov 27, 2003 | 01:38 AM
JKDZ28's Avatar
accually im doing a cam swap and im not going thru the hassle of having to do the lt4 chain yet
so im going to use the stock chain with the gear
the gear has the same amount of teeth and all it does is reduce chain slack
Old Nov 27, 2003 | 10:55 AM
Buttercup's Avatar
If the engine is stock you shouldn't have excessive slack. You don't want the chain too tight either
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
