Timing Cover Paper Gasket - Wet or Dry?
I'm about ready to instal my paper FelPro timing cover gasket. I wanna know... Do you install the gasket dry or with sealant? I was planning on using the High Tack gasket spray from permatex (blue can, red spray). What do you guys use? I want to do this right, absolutely do not want to pull it all apart later because of a leak!
oldschool
Feb 9, 2016 09:21 PM
