Timing Cover Leak? Is this common
Old Apr 27, 2003 | 04:33 AM
Twice The Fun's Avatar
just checking to see if this was a common leak point for LT1s, such as the intake gaskets....seems like i get one oil leak fixed here comes another...already did intake gasket, timing cover seals (still leaking from front cover tho), need a oil pan gasket, low oil sensor o ring....and tranny pan is leaking too....need a big @$$ diaper!
Old Apr 27, 2003 | 05:27 AM
sssalah's Avatar
Yes its somewhat common, and its a PITA to change the gasket, balancer hub, water pump, opti, oil pan....
good luck
Old Apr 27, 2003 | 07:08 AM
xxsaint69x's Avatar
yup, its pretty common.. you can easily fix it when u are puttin in a cam
Old May 21, 2003 | 04:34 PM
Luke 96 T/A's Avatar
I have a leak from my front timing cover too :9
I've replaced everything but the cover itself!!!!
Soooo.. that's the next step for me.....
Been in to the shop 3 times for the leak... I even had a new cam thrown in the last time (just for fun! ;-))
Old May 21, 2003 | 06:00 PM
if u buy the front cover from a GM dealership, or gmpartsdirect or sumthin GM.....the seals come with the front cover....all u need is a front cover gasket, and water pump gaskets, since u have to pull it also.
i can get part numbers for u if it would make it easier.
Old May 22, 2003 | 04:36 PM
EviLBoX's Avatar
I've got the same problem, that and the intake leak. They aren't leaking that bad, so I'm going to fix them when I get the cash to install a new cam.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
