Timing Cover Leak? Is this common
just checking to see if this was a common leak point for LT1s, such as the intake gaskets....seems like i get one oil leak fixed here comes another...already did intake gasket, timing cover seals (still leaking from front cover tho), need a oil pan gasket, low oil sensor o ring....and tranny pan is leaking too....need a big @$$ diaper!
I have a leak from my front timing cover too :9
I've replaced everything but the cover itself!!!!
Soooo.. that's the next step for me.....
Been in to the shop 3 times for the leak... I even had a new cam thrown in the last time (just for fun! ;-))
if u buy the front cover from a GM dealership, or gmpartsdirect or sumthin GM.....the seals come with the front cover....all u need is a front cover gasket, and water pump gaskets, since u have to pull it also.
i can get part numbers for u if it would make it easier.
oldschool
Feb 9, 2016 09:21 PM
