timing cover install
Old Jun 16, 2009 | 03:10 PM
ascastil's Avatar
i will try my best to make this as clear as possible. the rubber pan gasket that fits into the slot on the bottom of the timing cover, is the whole gasket supposed to sit in that slot, or only half? I got half of it in there easily with the pan dropped, seems nearly impossible to get the whole gasket in there, thats why i was wondering if i was doing it wrong.
Old Jun 16, 2009 | 03:29 PM
JAKEJR's Avatar
The gasket protrudes from the timing chain cover. Once the oil pan is put in place and bolted down, the gasket compresses, creating the seal.
There's a specific sequence of tightening the bolts found iN many manuals. I recommend you follow it to help insure no leak.
Jake
West Point ROCKS!
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
