timing cover
There should have been a freeze type plug that came with the electric water pump.
If not, you can get one at an auto parts store, put aviation gasket sealer on it and drive it in with a dowel and a hammer.
The freeze plug that comes with the ewp is to plug the back of the water pump.
Like stated earlier, you can plug the hole in the timing cover with a coin (some guys use 50 cent pieces; I couldn't find one so I used a quarter) and JB Weld.
Of course you could always weld it too.
I think Chad Golen put me on to this and it works great and looks good. You tap the hole with an NPT tap (can't remember the size) and then pug it with one of the anodized (colored) performance parts type allen socket pipe plugs. Put some thread sealer on it before installing.
WD
WD
oldschool
Feb 9, 2016 09:21 PM
