timing cover
Old Mar 31, 2007 | 01:55 PM
lr383's Avatar
timing cover
DO you guys have wear on the hole where the drive shaft for the water pump goes thur the timing cover? This is only on the top of the hole it seems to be gaulding up the top of the hole in the cover The shaft must be walking up some how under rpm. It as no leaks but little bit of Alum.is on the shaft. Thanks for relys.
Old Apr 1, 2007 | 07:29 PM
ChevyTuffD.A.'s Avatar
I'm sure its a pretty common thing. As long as it aint leaking then I wouldnt worry about it.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
