Timing chain went. Any recommendations?
Old Aug 15, 2003 | 04:13 PM
Durbn4duke's Avatar
What is a popular one for a descent price. What do you run? Also where can I find it.
Old Aug 15, 2003 | 04:42 PM
lt1form's Avatar
GM LT4 HEAVY DUTY but is lots of $$$$$ over $200.00 I think.
Check with www.gmpartsdirect.com maybe cheaper.
Cloyes (sp) makes one too not sure of price.
Old Aug 15, 2003 | 04:49 PM
speedmiser's Avatar
If your running the non-vented opti, then I believe you're stuck with either the stock chain, or the lunati set. Havent heard much feed back on the lunati set though - it's a link belt chain like the stock piece. While Lunati claims is a better HD piece, their own tech line didnt know enough about it to tell my why or how it was better.
Old Aug 15, 2003 | 10:39 PM
car_ramrod's Avatar
im a firm believer in the electric water pump, vented opti cover, REAL timing chain setup. if you switch to the electric pump and the right opti cover you can go with a much cheaper yet much stronger timing chain like a cloyes, or whichever you prefer. i know CMotorsports can hook you up. the LT4 ED just isnt worth the money to me.
CR
Old Aug 16, 2003 | 02:44 AM
Durbn4duke's Avatar
Are you guys saying that the lt4 chain from thunderracing for $300.00 wont work?? whats the website for that cmotorsports,... www.cmotorsports didnt work for me. Also i am gonna go with the electric pump, but whats a vented opti cover?? Can i just buy 1??? and where? How much is a cloyes timing chain?? Sorry about all the questions, im clueless.
Old Aug 16, 2003 | 02:52 AM
atljar's Avatar
In order to run the cloyes/electric h20/ you need to switch to the vented opti spark. That requires new opti, timing cover, vacuum lines, and opti pigtail. However, this is a really nice set up and upgrade from where you are now. You get a super nice timing chain, a better opti design, and an electric h20 to free up some ponies and keep the car cooler. Thats the same setup i switched over to.
Old Aug 16, 2003 | 02:59 AM
Durbn4duke's Avatar
As much as id love to, i cant get a new opti, way too much $$ at the time. whats my options on a timing chain that will fit my setup. i have the mezeir pump, but non vented opti.
Old Aug 16, 2003 | 02:03 PM
atljar's Avatar
You can go with the stock chain, and an oversized sproket to tighten it up (or lt4 like that), or go with the extreme duty chain. I have an extreme duty chain laying in a box in the garage that was on my car for 3-4k miles. Took it off when i went double roller. It was a little too loose for my likes, but def better than stock. Has crank sproket, cam sproket, and chain. Let me know if you are interested. ThunderRacing also sells a bigger sproket for the extreme duty chain to tighted it up
Old Aug 17, 2003 | 09:23 PM
speedmiser's Avatar
I'm confused. How's he going to run the ED or LT4 chain and gears without converting to vented opit??? Didnt think that was possible.
Old Aug 18, 2003 | 12:29 AM
atljar's Avatar
actually, hmmm. The double roller is a for sure you need the vented opti. I thought the lt4/ED was ok on both versions. I used that timing set of my impala SS(vented) so i didnt have any issues.
Can anyone say for sure that the lt4 will work/wont work on a non vented car?
atljar's Avatar
Old Aug 18, 2003 | 01:10 AM
blueirocz-28's Avatar
JARED, QUIT DOUBLE POSTING, POST *****...
now to stay on subject, i do believe that the ED chain will accept the non vented opti. but the cloyes double roller does have to be converted to vented opti/electric water pump.
Old Aug 18, 2003 | 01:25 PM
Durbn4duke's Avatar
I dont get it??? whats a vented opti? will a double roller just not fit, or whats the deal? Whats my best option then?? im not getting a new opti.
Old Aug 18, 2003 | 01:30 PM
atljar's Avatar
Non-vented opti were on the 93-94 cars
Vented optis are on the 95-97 cars
The reason sone timing chains work, and others dont is with how the opti is turned. Here is the best explaination possible
http://para.noid.org/~muttvette/opti.html
Old Aug 18, 2003 | 01:33 PM
atljar's Avatar
Also on that page, it states that the lt4 and ED chains cant be used on the old opti sparks, so i was incorrect.
ONly option is get an oversized sproket for the stock chain.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
