Timing chain and water pump recommendation
Old Mar 16, 2010 | 08:01 PM
mrl510's Avatar
i have a 97 z28 motor thats now a 383 and is going to run about 12psi -15psi boost. Shooting for 600hp. Im trying to finish the motor up now. What timing chain and water pump would yall recommend. Thinkin about switching to a electric water pump and and maybe the Cloyes 9-3145 timing chain set. But if i use that chain set, wont i have to delete my relucter ring and crank sensor thats in the timing cover? Or what setup would yall recommend for the motor setup, maybe heavy duty lt4 chain set and mechanical water pump? Not for sure. What do you think i should do.
Old Mar 16, 2010 | 09:13 PM
koolaid_kid's Avatar
I went with the electric water pump for the simple reason that it eliminates one of the main causes (IMHO) of Opti failure: the rear bearing (or seal) failing in the mechanical pump and leaking on the Opti.
I also used the Cloyes 3145, but had to clearance the timing cover, block the wp drive hole, etc.
It takes a bit of work; thought, careful planning and execution, including the water pump relay circuit and warning leds.
Opinions will vary on these mods, of course.
Old Mar 17, 2010 | 11:51 AM
Jlo's Avatar
Jlo
Is it really necessary to block the wp drive hole on the block? and won't the stock timing chain hold with the increase in HP, I've read posts here and some of these guys run the stock timing chain on 383's,355, 396 and on cams such as gm847, cc306 etc.. just wondering..
Old Mar 17, 2010 | 12:13 PM
97FormulaWS-6's Avatar
You don't have to block off the drive hole in the block; you do the timing cover though.
The stock timing chain will hold a good amount of power; but a lot of people upgrade just for the piece of mind.
Old Mar 17, 2010 | 05:25 PM
mrl510's Avatar
when you use the cloyes 3145 chain and gear set, do you have to eliminate the relucter ring and crank sensor in the cover?
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
