Timing chain and water pump reccomendation
Old Mar 16, 2010 | 09:00 PM
mrl510's Avatar
i have a 97 z28 motor thats now a 383 and is going to run about 12psi -15psi boost. Shooting for 600hp. Im trying to finish the motor up now. What timing chain and water pump would yall recommend. Thinkin about switching to a electric water pump and and maybe the Cloyes 9-3145 timing chain set. But if i use that chain set, wont i have to delete my relucter ring and crank sensor thats in the timing cover? Or what setup would yall recommend for the motor setup, maybe heavy duty lt4 chain set and mechanical water pump? Not for sure. What do you think i should do.
Old Mar 16, 2010 | 11:45 PM
MikeGyver's Avatar
I believe the crank sensor is only for detecting misfires.
instead of going with a factory link chain and pump, I went with the better and cheaper cloyes 3145 and a CSR electric pump for my turbo 383 that i'm finishing up. I found that CSR's supposed 'great' I'll try Meziere next time for sure.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
