timing chain slack
Old Mar 9, 2008 | 08:27 PM
drperformance's Avatar
timing chain slack
How much timing chain slack is ok?
I just pulled my timing cover off my 95 383 LT1 and measured movement somewhere around 5/8" midway between the cam and crank gears. This is a newly professionally built LT1 with less then 500 miles (hard miles), and I beilieve that it is a cloyes billit steel rollor style with 9 crank keyways (one for a normal chevy 350, I deleted the gear driven water pump). Should I be concerned? Is this too much play?
Old Mar 9, 2008 | 11:24 PM
sn8ke eatr's Avatar
mine had probably about an inch after 180k miles
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
