Timing chain question for upgrade...
Old Mar 1, 2004 | 03:01 PM
  #16
fastcamz28's Avatar
I have a Hot Cam in now w/ plans to go to a CC 306 after heads and block work, and still retain my unvented opti. Haven't heard/seen anything that would suggets this won't work. I do have a CSI water pump.
Thanks!
Old Mar 1, 2004 | 03:06 PM
  #17
Hawk350's Avatar
Thanks!!!
Old Mar 1, 2004 | 04:26 PM
  #18
93TA's Avatar
fastcam,
you're planning to use the stock timing set with the 306 cam?(that's most likely the cam i'm going with - but i was under the assumption the stock timing set would not handle the rpms)
thx
larry
Old Mar 1, 2004 | 04:33 PM
  #19
fastcamz28's Avatar
I will check w/ my engine builder (he's not in right now!) and post his response. I'll do a search as well to see if there's anything in the archives on this topic.
Thanks!
  #20
jonaddis84's Avatar
Joe Overton uses a stock 94 timing set to go 9.7s @138mph...just some food for thought..he only puts 20-30 passes on it though and replaces every winter, but regardless..
Old Mar 1, 2004 | 04:38 PM
  #21
fastcamz28's Avatar
That's what I was wanting to hear!
Thanks!
Old Mar 1, 2004 | 06:49 PM
  #22
ibanez6rg's Avatar
Thanks!
You gotta understand though he probably tears into his motor a lot... is that something you wanna do? Take the time and money to do it once or take the time and money to do it over and over again. Just some more thought...
Old Mar 1, 2004 | 07:24 PM
  #23
93TA's Avatar
anyone know what is harder on the timing chain - the higher rpm you run w/ a 306 cam or the steeper lobe angles of a ex230/236 cam?
Old Mar 2, 2004 | 08:26 AM
  #24
Hawk350's Avatar
Good question...I am sticking with the stock timing set because I dont plan on being at the track too often....and I dont plan on taking my car beyond 6000rpms anyways....so stock should do.
Old Apr 21, 2004 | 02:52 PM
  #25
hot_red_z28's Avatar
so is the lunati set really worse off than a stock replacement one?
Old Apr 21, 2004 | 03:22 PM
  #26
GREGG 97Z's Avatar
Most of us arent tearing into our engine every year though to switch cams and replace the timing set, at least I'm not.
I took my stocker out at 57K when I did the cam last year, up until then it had bolton's only since about 40k and was around 300rwhp. I was pretty surprised at how loose my original chain was, it had a lot of play in it, I could move it back and forth a good inch. I went with the Cloyes roller, I'm very glad that I upgraded it to something stronger.
Old Apr 21, 2004 | 09:04 PM
  #27
Hawk350's Avatar
From what I have been reading, the stock chains with stockj sprokets are made to be loose. I am going to purchase the cloyes oversized sproket to get rid of most of the play in the chain. I have spoked with my engine builder and he claims 400hp cars are fine with the stock chains. I am going to get a new chain and sprockets when installing the application.
Old Apr 22, 2004 | 06:22 AM
  #28
SLeePer350's Avatar
So lets clear something up....
I have a 94 formula. Therefore non vented opti. However when doing a cam swap, does the dowel need to be shorter for non vented? If a cam meant for a 95+ car is installed on a 92-94, then what can be done to make this work??? Simply cut the dowel down? is this safe? (I want to do this without swapping to a vented opti)
this thread is starting to get confusing...
Old Apr 22, 2004 | 07:50 PM
  #29
Hawk350's Avatar
I think the dowl is a bit longer on the 95+, the face of teh cam has a bigger opening to accomodate the vented opti as well. Not sure if this will work. I am getting a cam ground for the 94'....so it will look stock.
Old Apr 24, 2004 | 01:18 PM
  #30
Hawk350's Avatar
Ok, cam is picked out....230/236 with 112 lsa thanks fellas.
