timing chain placement ..please help
Old Nov 16, 2003 | 12:51 AM
YOSHI`S Z28's Avatar
hey,
i got the old timing chain and gears off im ready to replace them.
question is.. where do i put the alignament marks on the gears to sit.. and while doing this do i have to put my number one piston at tdc....
another question...do i have to loosten my oil pan to put my timing cover back on or can i do it as is?
thanks in advance
josh
Old Nov 16, 2003 | 03:20 AM
madwolf's Avatar
Well, the sprockets will only go in one way, so you can't mess it up there. Easiest way to see if you got the chain installed right is by aligning dot to dot. Once you got the chain installed, do a couple of full turns to make sure the alignment stays the same.
I would loosen up the oil pan if I were you. I had a hard time putting mine in with the oil pan loose (new gasket) so you get the idea. Others have managed to put it back on without problems but I wouldn't take the chance.
Old Nov 16, 2003 | 03:23 AM
madwolf's Avatar
Oh yes, forgot to mention. Dot to dot is #6 TDC. Cam dot at 12 and crank dot at 12 is #1.
Old Nov 16, 2003 | 08:04 AM
well,
i put them on and i have the crank dot at 12 and the cam dot at 6 to where they point at eachother?
does that sound right, i really dont wanna mess this up, id hate to take this off again
thanks
josh
Old Nov 16, 2003 | 08:19 AM
joeSS97's Avatar
Yes,that is right.Make sure they line up perfectly.Like Madwolf said,spin the motor over and check it.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
