Timing chain options for LT1 while KEEPING mechanical WP
Old Feb 12, 2008 | 07:20 AM
Rising Phoenix's Avatar
What options are there besides stock replacement and the GMPP "extreme duty" for timing chains, if one wishes to retain the mechanical drive waterpump?
Old Feb 12, 2008 | 08:59 AM
96m6lt1's Avatar
you pretty much named the best ones to use,you left out the original Lt4 factory chain..
Old Feb 12, 2008 | 10:35 AM
Does the Extreme Duty set work fine with the stock cover or does it need to be clearanced?
Old Feb 12, 2008 | 10:44 AM
Dave1980's Avatar
I am pretty sure there is no clearancing.
Old Feb 12, 2008 | 11:15 AM
Bersaglieri's Avatar
Comp makes one, but it's not worth the price.
-Dustin-
Old Feb 12, 2008 | 11:18 AM
AJ52486's Avatar
I'm running the extreme duty timing set. I didn't have to modify anything, it just bolted on.
Old Feb 12, 2008 | 11:35 AM
Thanks guys.
Old Feb 12, 2008 | 11:59 AM
dangalla's Avatar
mine is a stock replacement, whats wrong with that? cheaper and i dont know of any failures
Old Feb 12, 2008 | 02:21 PM
whitehooptie's Avatar
A sbc timing chain is identical to an LT1 chain. That opens up a few more options.
Old Feb 12, 2008 | 02:23 PM
dangalla's Avatar
he wants to keep mechanical water pump so a gear SET will have to be for an lt1
Old Feb 12, 2008 | 02:59 PM
ABA383's Avatar
The stock chain is plenty strong...I still run a stock one which I replaced in 2005 when we did the cam swap just as PM...Never had any issues with it at all...
--Alan
Old Feb 12, 2008 | 03:30 PM
I guess it really boild down to if the OP is referring to the chain only or the timing set. It seems he is referring to the set, but it is not perfectly clear to all.
Old Feb 12, 2008 | 04:02 PM
I was referring to the set, my bad.
And not to attention ***** or anything, but it is she, not he.
Old Feb 12, 2008 | 04:59 PM
Sorry, I could not tell...
Old Feb 12, 2008 | 05:04 PM
well i have in that case, we need pics!. just kidding, but that only difference is the cam gear. the crank gear and the chain are the same. I used to get new cam gears from the dealership for real cheap, that's why I suggested a sbc chain.
but seriously, where,s the pics. :P
damn this phone is hard to type on..........
