Timing Chain Help, which one
Old Dec 8, 2006 | 01:02 PM
rickyzZ28's Avatar
I did a search and found that everyone on here generally uses the CLO-9-3145 when they switch to a double roller. A motor I am putting together has an e-water pump and is a 95. My question is what is the difference between the CLO-9-3145 and the CLO-C-3039. The CLO-C-3039 says that it is a replacement for our motors. Does everyone just run the 3145 because it is adjustable or is there some other reason?
here is a link on summit if it works
http://store.summitracing.com/compar...=KeywordSearch
Old Dec 8, 2006 | 02:30 PM
Probably because the 9-3145 is the TrueŽ Roller version that is stronger.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
