Timing chain cover gasket
Old Aug 7, 2006 | 10:54 AM
Bobsep84's Avatar
Hey guys, my optispark is starting to take a dump so i am going to change it in the next week or so. After looking at a few things it looks like the timing chain cover might be leaking on the opti...its really hard to tell tho...would this cause it to fail? I know to get the cover off you need to drop the oil pan alittle...but won't that ruin the gasket on the pan...and if so..how would i replace that?
Old Aug 7, 2006 | 11:01 AM
Javier97Z28's Avatar
Moderator
Re: Timing chain cover gasket
Doubtful that the timing cover gasket itself is leaking, that's a rare paper gasket to fail.
More likely that one of the seals (wp seal, opti seal) is leaking.
If it turns out that you do have a timing gasket leak, and the oil pan gasket tears, just use lots of RTV in the mating corners and it will seal right up, done it a ton of times during cam installs.
Old Aug 7, 2006 | 11:38 AM
Bobsep84's Avatar
Thats what i was thinking too...i always hear stroys of the WP leaking onto the opti. If thats the case..do i need a new WP as well or just a new WP gasket?
Old Aug 7, 2006 | 11:55 AM
Moderator
Well, the WP isn't leaking if the weep hole is dry. When a water pump goes, it goes.
I'm talking about the oil seal for the shaft. If it's that that is leaking, just replace the seal. No need for a new pump, not even part of it.
Old Aug 7, 2006 | 12:13 PM
Bobsep84's Avatar
Where would i get that seal?
Moderator
Any auto parts store...
Old Aug 7, 2006 | 12:25 PM
Bobsep84's Avatar
Is there any part number i should look for or brand?
Old Aug 7, 2006 | 12:54 PM
Moderator
Any brand will do, not sure of the part # off the top of my head. Might be on shoebox's website: www.shbox.com
Old Aug 7, 2006 | 02:12 PM
Bobsep84's Avatar
Awesome, thanks for your help
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Snoman73
Nov 17, 2014 07:22 PM
