Timing Chain
Old Mar 24, 2009 | 02:51 PM
joshmullins8's Avatar
Question Timing Chain
I need a timing chain for my 94 LT1, I cant find any can anyone send me some links or something please? Im rebuilding the engine and already got a mechanical waterpump, theres a cloyes timing chain that I already bought but it wont work cause I would need a electrical waterpump. So please help me out here.
Old Mar 24, 2009 | 02:56 PM
ulakovic22's Avatar
You need to get a stock replacement timing chain. It's made by Cloyes as well and you can pick one up at AZ, O'Reilly's, etc. If you want to go single roller then you will have to go LT4 ED set as the stock sprockets are designed for link chains, not roller chains.
Old Mar 24, 2009 | 03:23 PM
I have a the LT4 Hot Cam kit that Im about to install with it so what exactly do I need?
Old Mar 24, 2009 | 03:34 PM
Is the 94 Z28 Lt1 a roller motor?
And when I have the mechanice install the LT4 Hot Cam, hes gonna have to do extra machine work for it to fit?
Will the LT4 Hot Cam work with a non roller timing chain?
Old Mar 24, 2009 | 03:36 PM
stantheman601's Avatar
here is the part number for the stock replacement chain. 10128485
cloyes has a chain that says stock replacement but its really a single roller chain. im sure they have a real stock replacement one but i havent seen it. i would jus go with the number i gave you. it the GM stock chain. just use that number at summit. i think it was $50. thats the way im going.
Old Mar 24, 2009 | 04:21 PM
Stantheman601 thanks alot. Do you or anyone else know if the stock timing chain will work with the lt4 hot cam? I dont see why it wouldnt.
Old Mar 24, 2009 | 06:39 PM
RamAir95TA's Avatar
You need to replace the entire set, not just the chain (cam and crank sprockets). Putting a new chain on old sprockets is not a good idea.
Chain - 10128485
Cam Sprocket - 10128349 (93 - 94 style)
Crank Sprocket - 10128346
The hotcam kit is a direct swap. There's no machine work necessary.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
