Timing Chain?????
Old Dec 16, 2006 | 12:46 AM
  #16
TobyZ28's Avatar
When i was looking up a replacement chain i saw someone post about their stock chain getting stretched so far they were able to take the chain right off! It wasn't even that high milages (but the guy did beat the car pretty hard)
Old Dec 16, 2006 | 01:06 AM
  #17
Wild1's Avatar
Good idea to use grease as a marker. That makes it easier to grind. Thanks for the tip.
Old Dec 16, 2006 | 01:20 AM
  #18
TransAm396's Avatar
Originally Posted by Z95m6
Yeah and there was a guy on here that went out and snapped a brand new stock chain on his 383 on the first or second WOT run. Many others on here have had stock chaings break. The stock chain also can stretch and produce inaccurate valve timing, which hurts performance as well. Its not a good idea to run a stocker.
then something was wrong, bcuz Ive never heard of anyone actually breaking one. Maybe the gears were misaligned or something but I dont see how they could just BREAK esp on the first WOT pass..had to be a faulty chain or a problem elsewhere. I understand the stretch thing but mine was 100% normal and I beat it worse than someone should beat their car...almost like I tried to break it. I can see if you have a full race motor you might want to go bigger but for just a simple cam swap I dont think you really NEED anything else.
Old Dec 16, 2006 | 11:32 AM
  #19
SS RRR's Avatar
some stock chains may take the abuse more than others. why take the gamble? my good friend, Shawn97Z28M6 on this board snapped his when he had to slam on his breaks and that was when the cam/springs were stock. it had around 30K miles on it. he was lucky and only had to replace the valves. pistons made contact, but did not damage them and he went on to drive it for many more miles. a roller chain is cheap compared to having to go through the trouble of either simply replacing valves or possibly pistons.
there is no logical argument that can be made to state a stock chain will be fine with higher spring pressures.
Old Dec 16, 2006 | 11:35 AM
  #20
TransAm396's Avatar
Ok well maybe the fact that I used beehives made a difference cuz I used stock lifters too and they were perfect.But alls im saying is it worked..and worked very well, and its worked for many people I know.(not trying to get into an argument)
Old Dec 16, 2006 | 02:04 PM
  #21
JimboManJones's Avatar
Are there any single roller chains that'll work on an lt1(with ewp)? Double roller seems like overkill, and I would prefer not to have to clearance the cover, also is there any interference with the crank position sensor when using the cloyes(on obd2 cars that is)?
Old Dec 16, 2006 | 02:29 PM
  #22
TransAm396's Avatar
I used a stock chain like I said and it was fine for me with the beehives spinning it to 6600 rpms daily
Old Dec 16, 2006 | 02:49 PM
  #23
Z95m6's Avatar
You could go with an LT4 Extreme Duty and still run an electric pump.
Old Dec 17, 2006 | 04:28 PM
  #24
taylorcrzy's Avatar
Since I have a 95 I am going to do the grind work and seeing that I just ordered a Cloyes I am stuck I guess. I will keep this forum posted.
Old Dec 17, 2006 | 04:32 PM
  #25
Are there any cheaper solutions that don't require clearancing the cover but still just as strong, like will any SBC chain work(since I don't have an ewp) or will there be interference witht eh crank position sensor?
EDIT: for the price I think I'll just suck it up and clearance the cover, but still does anyone know about the crank position sensor?
Old Dec 17, 2006 | 05:54 PM
  #26
Z95m6's Avatar
You'll have to lose teh crank position sensor if you go double roller.
Old Dec 17, 2006 | 06:39 PM
  #27
TransAm396's Avatar
whats the need for the CPS anyways? does it help with anything?
Old Dec 17, 2006 | 06:58 PM
  #28
Dave89IROC's Avatar
misfire detection only, if you get rid if it, you will need to tune it out of the PCM, no biggie since you will be getting a tune anyway(you are, right??)
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
