Timing Chain?
Old Dec 15, 2004 | 02:32 AM
Meen95z's Avatar
Question Timing Chain?
I am rebuilding my motor with 143k late January. Im on a really tight budget. Is it safe and can you put a lt4 timing chain on stock gears? If not, can i just replace the chain and will it be ok? Just doin mild mods, nothin to big.
Old Dec 15, 2004 | 02:55 AM
speedmiser's Avatar
Re: Timing Chain?
With that many miles, you need to replace the chain and the gear set. It's pretty inexpensive for the stock pieces. With a chain that old, I'm sure there has been a lot of stretch, and there is probably heavy wear on the lead side of theh crank gear.
I defintely wouldnt try to put lt4 or x-treme duty chain on stock gear set. I don't think the links are the same size, but regardless, that sounds like a potential disaster.
Old Dec 15, 2004 | 03:05 PM
Meen95z's Avatar
Re: Timing Chain?
Can anyone find a Lunati or a good timing chain for a 95-97 LT1 for under $200??? Besides a Double Roller or the Extreme LT4
Old Dec 15, 2004 | 03:08 PM
SSmoked's Avatar
Re: Timing Chain?
Just get the stock chain and sprockets. I spend 120$ for mine from auto zone. If ur gonna be keeping it pretty much stock you will be fine. Now if your gonna be dropping afew thousand into the motor, then id say GM performance parts.
Old Dec 16, 2004 | 01:20 AM
Meen95z's Avatar
Re: Timing Chain?
Im doing a rebuild with hot cam, lt4 intake, ported heads stock valves and longtubes. Will the Hi_Tech for 101.99 from autozone be ok? Or a stock timing set.
Old Dec 16, 2004 | 01:46 AM
blazzinbird's Avatar
Re: Timing Chain?
the lanauti timing set is just a gm timing set same numbers on it
anyways if you wanted you can get a dubble roller setup for around 70 dollars from cms
Old Dec 16, 2004 | 01:50 AM
Z95m6's Avatar
Re: Timing Chain?
You can get the ED LT4 for around $200. I thought it could be had from Jason Cromer for about $180.
Old Dec 16, 2004 | 03:52 AM
cmking26's Avatar
Re: Timing Chain?
Summit has a lunati set for $110.
Old Dec 16, 2004 | 07:11 AM
Myxtreme1's Avatar
Re: Timing Chain?
I am using the GM performance one I got from a very respectable member of this board.
Old Dec 16, 2004 | 03:36 PM
Meen95z's Avatar
Re: Timing Chain?
I dont want a double roller cause then i need a electric water pump and a Lunati is only for 92-94 and i got a 95. So its either the LT4 for 245 or hi tech on for 102? If the lt4 isnt really necessary then i cant afford to waste money.
Old Dec 16, 2004 | 03:47 PM
"White Knight"'s Avatar
Re: Timing Chain?
I wish I had a 95 with a vented opti
Dang non-vented optis
I have no idea what chain i'm going to use either, but at least you have more options
Old Dec 16, 2004 | 04:16 PM
93ZM6Tally's Avatar
Re: Timing Chain?
For the price of the LT4 chain you can just about get the electric water pump and go with a double roller. If that's too much go with the stock replacement - should hold unless you get pretty crazy.
Old Dec 16, 2004 | 06:10 PM
Z95m6's Avatar
Re: Timing Chain?
When i got my ED LT4 chain i got it through GM parts direct for just under $200 + their high shipping which is probably $20. I do remember after that my buddy called Jason Cromer and i thought he wanted only $180ish for the set. I would call Jason Cromer.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
