Timing Chain?
I am rebuilding my motor with 143k late January. Im on a really tight budget. Is it safe and can you put a lt4 timing chain on stock gears? If not, can i just replace the chain and will it be ok? Just doin mild mods, nothin to big.
Re: Timing Chain?
With that many miles, you need to replace the chain and the gear set. It's pretty inexpensive for the stock pieces. With a chain that old, I'm sure there has been a lot of stretch, and there is probably heavy wear on the lead side of theh crank gear.
I defintely wouldnt try to put lt4 or x-treme duty chain on stock gear set. I don't think the links are the same size, but regardless, that sounds like a potential disaster.
Re: Timing Chain?
Just get the stock chain and sprockets. I spend 120$ for mine from auto zone. If ur gonna be keeping it pretty much stock you will be fine. Now if your gonna be dropping afew thousand into the motor, then id say GM performance parts.
Re: Timing Chain?
Originally Posted by Meen95z
Can anyone find a Lunati or a good timing chain for a 95-97 LT1 for under $200??? Besides a Double Roller or the Extreme LT4
Re: Timing Chain?
I dont want a double roller cause then i need a electric water pump and a Lunati is only for 92-94 and i got a 95. So its either the LT4 for 245 or hi tech on for 102? If the lt4 isnt really necessary then i cant afford to waste money.
Re: Timing Chain?
Re: Timing Chain?
