timing chain
Old Oct 26, 2003 | 10:12 PM
DarkRider's Avatar
timing chain
been trying to find a full roller chain for my car but haven't found one yet - do you have to get them from dealer or is there someone who makes an aftermarket chain.
Old Oct 26, 2003 | 10:14 PM
FacelessZ's Avatar
Cloyes Double-Roller Timing Chain
CLO-9-3145 $79.95 (Summit Racing)
Old Oct 26, 2003 | 10:22 PM
Compstall's Avatar
....and will that one fit the factory sprockets?
Old Oct 26, 2003 | 10:24 PM
DarkRider's Avatar
under the technical tab it says that it will not fit LT1?
Old Oct 26, 2003 | 10:30 PM
FacelessZ's Avatar
it does...with a double roller you have to grind some of the timing cover in order to get it to fit...
Old Oct 26, 2003 | 10:39 PM
95_RipperZ's Avatar
www.cmotorsports.com has one for $59 and it is has a stronger sprocket than the cloyes i hear. I used it in my car.
Old Oct 26, 2003 | 10:49 PM
madwolf's Avatar
You guys are forgetting one "minor" detail. An electrical waterpump conversion is required with a double roller.
Old Oct 26, 2003 | 10:51 PM
FacelessZ's Avatar
thank you madwold...btw I'll be hitting you up about some tuning in the next few months...
Old Oct 26, 2003 | 10:57 PM
DarkRider's Avatar
does the oil pan gsket have to be changed when you do the timing chain
Old Oct 26, 2003 | 10:58 PM
FacelessZ's Avatar
thats a big no...
Old Oct 26, 2003 | 10:59 PM
madwolf's Avatar
Not if you're careful.
You will have to loosen up most of the oil pan bolts to get enough clearance for taking off the timing cover.
Old Oct 26, 2003 | 11:06 PM
DarkRider's Avatar
say I screw up the gasket - is it changable w/o jacking up the motor
Old Oct 26, 2003 | 11:07 PM
madwolf's Avatar
If you loosen up those bolts first, you won't screw it up. If you do though, yes, you can change it without jacking up the motor.
Old Oct 26, 2003 | 11:27 PM
DarkRider's Avatar
how much of the timing cover do you have to grind off to get the cloyes to fit-do you grind it with a dremel tool?
Old Oct 26, 2003 | 11:29 PM
madwolf's Avatar
Not much really. I think some didn't have to grind at all.
Dremel will work just fine.
