Timing chain
Old Jun 10, 2003 | 03:07 PM
94formulabz's Avatar
Timing chain
When doing a cam swap do i need to replace the whole timing set or can i get away with just replacing the chain if there is no abnormal wear? Car has 57k mi
What is the best option for the whole set? the LT4 XDuty is 200 from gmpartsdirect. Is there something quality aftermarket for less? I don't want to switch to the vented opti.
Old Jun 10, 2003 | 04:57 PM
Camaro_Maniac63's Avatar
You don't have to replace the timing chain, but you will be better off if you do. A heavy duty timing chain will give you the peace of mind at higher RPMs. With a heavy duty timing chain, it is more about reliability than it is about performance. I don't know about any other aftermarket timing chains, but my LT4 XDuty Timing Chain works damn good.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
