timing
Old Jul 10, 2009 | 01:11 AM
sam mccoy's Avatar
timing
ok i had to replace the o-rings on my 95 camaro z-28 and when i put the the dristuribtor back in it would not start i have put the car at TDC and then put the dristurbitor back in and still nothing can anybody help
Old Jul 10, 2009 | 05:24 AM
Are you sure you have the dowel pin in the correct hole in the back of the Opti? Are you sure the pin is engaging the Opti?
http://shbox.com/1/opti_back.jpg
Are you getting spark at all? Are you getting fuel?
Old Jul 12, 2009 | 12:18 AM
Rich2279's Avatar
I seem to remember the LT1/LT4 book saying to have cylinder #1 @ TDC on the compression stroke, which will place both the cam sprocket mark and cranksprocket mark at the 12 o'clock position. The cam dowel pin should also be in the 9 o'clock position. Then you can slide the distributor in with the cam dowel going into the correct slot on the back of the distributor.
Old Jul 12, 2009 | 12:46 PM
Stl94LT1's Avatar
It doesn't matter where it is in the firing order or TDC. As long as you hit the right slot in the opti, it will work.
The pic "injuneer posted, courtesy of "shoebox".
Old Jul 12, 2009 | 02:11 PM
Rich2279's Avatar
Much easier that what the book mentions. LOL
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
