Which timeing set?
Old Jun 2, 2008 | 10:33 PM
TehFonz's Avatar
Which timeing set?
Alright guys im building a forged blower motor and am wondering what would be the best timing set for this build. Also how much is the stock crank rated for? Just wondering.
Old Jun 2, 2008 | 10:41 PM
Answer depends on year, type of opti and water pump.
Old Jun 2, 2008 | 11:01 PM
TehFonz's Avatar
Im sorry i have a 93 z28 im goin to keep cam driven water pump and non vented opti i believe.
Old Jun 2, 2008 | 11:18 PM
You are prettly much stuck with a stock set, then.
Old Jun 3, 2008 | 07:51 AM
seawolf06's Avatar
That's the truth. Get an electric wp and you can go to a Cloyes Double Roller timing chain.
I have been told that the stock crank is good to around 500fwhp, NA. Not sure if you can throw a lot of nitrous at it because it is cast, but a little nitrous is probably ok.
Old Jun 3, 2008 | 07:57 AM
He would need a lot more than an electric water pump (like an opti conversion). It's the non-vented opti that is the limiting factor in the timing gear set selection.
Old Jun 3, 2008 | 12:07 PM
TehFonz's Avatar
I'm building a blower motor for around 13-15 psi i can get a forged crank but ill have to save me some moneys. So far i have je forged -31 cc pistons, Eagle esp h beams. I would like to see almost 600 rwhp but thats being optimistic. I have most other supporting mods for around 650 hp. so im building my motor. Ive toyed the idea of an electric water pump around but i don't want to lose my reliability. So i don't know as of now. What do y'all think?
Old Jun 3, 2008 | 12:51 PM
mzgp5x's Avatar
I did a 97SS 383 D1 M6. Did a Mezz WP option. Did not like the WP drive system and the seal that leaks alot. I did a GM LT4 timing chain option before the Electric mod, but, I would now do the Cloyes after market. I still run the vented opti with my own mods to the rotor to run MSD ign parts. I recc the Pioneer keyed hub available from Thunder racing. B.
Old Jun 4, 2008 | 01:25 PM
1993zlt1's Avatar
go wit the lunti set from summit for the lt1 its for 92-93 lt1s thats what i have and its nice and works great. around 162 buck tho.
Old Jun 4, 2008 | 05:22 PM
If the pics are accurate for the Lunati set, it is stamped with the normal GM part numbers. You could just buy the GM pieces for less.
Old Jun 4, 2008 | 11:08 PM
1993zlt1's Avatar
Nah i think thats just a sample mine didnt have any numbers on the gears well maybe a symbol or 2 but no GM blah blah blah numbers.
Old Jun 5, 2008 | 07:54 AM
1963SS's Avatar
You can pick up a few horses and eliminate the opportunity for an oil leak by going electric W/P. I used a Cloyes 3157 true roller. It fits perfectly (no grinding) is very tight, and has very large, strong rollers. I think it was around a hundred bucks.
I just had the hole for the W/P drive welded up. The guy charged $20.00.
Another advantage is that if your water pump ever goes bad it won't destroy the non-vented opti.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
